How to make default Comments field mandatory in Worlflow transition
Nandeesh M S July 23, 2014
When we add a screen to workflow transition comments field will appear by default. so how to make that default comment field mandatory for particular transitions? Pls help.
Pls find attachment
Nandeesh M S
Andrey Markelov
July 23, 2014
Andrey i already tried this plugin. It is for omiting groups which dont want to add comments while transition.
I want to make default Comments field to be mandatory for particular transition Andrey.
Andrey Markelov
July 23, 2014
You mean I need to add extra configuration feature?:-)
I will add it to queue. Good idea.
Andrey Markelov
July 23, 2014
And why "Comment Validato" doesn't work? I don't understand I bit. You can not setup any groups and comment will mandatory for all users which perform current transition.
please refer screenshot Andrey...
2. When i select that next it will ask to select groups.
pls refer screen shot Andrey
1. i am selecting comment validator
Andrey Markelov
July 23, 2014
Yes. I believe there is empty option. So if you set empty options the comment will be mandatory for all users in Jira.
Nandeesh M S July 24, 2014
Thanks a lot Andrey. It worked :)
Sir Be July 23, 2014
I have done something quite similar (in Jira 4.2).
I have created a free-text custom field, and added that field to certain screens.
There are validators in the workflow that can check of certain fields are filled in.
Afterwards you can add a post function 'add comment from field' (don't know the exact name), where you can set the author and field.
Helpful?
Hi Sir Be thanks for you comment. I know to add extra custom field like comments but if we add extra filed also this default comment field will be visible. So totaly 2 comments fields will be visible. I dont want two comment fileds.
That's a good point! :)
