How to make either of the two fields required on create transition?
Nikhil
I have two dropdown (select list - Single choice) fields "Internal Group" and "External Group"  which I'd like to add on create screen. As per the project needs, users create tickets for field values of either of 'Internal Group' or 'External Group' field.
Options for fields:
Internal Group: A, B, C
External Group: 1, 2, 3
Let's say suppose I am creating a ticket for 'Internal Group' - A, I'd like to make 'Internal Group' as a required field and 'External Group' as an optional field and proceed with ticket creation.
Likewise, If I am creating a ticket for 'External Group' - 1, I'd like to make 'External Group' as required and 'Internal Group' as an optional field.
Can we in Jira add some logic so we can mark both fields as required and automatically make one of them optional based on value selected in other field?
Any groovy scripts to achieve this will also be of big help. Thanks!
Marco Brundel
December 2, 2024
At a client of mine I have built a validator with JMWE Build-your-own validator on Jira DC. With the groovy script
issue.get("Field A") || issue.get("Field B")
Marco Brundel
October 30, 2019
Hi @Nikhil ,
Maybe you can use a Simple scripted validator of Scriptrunner.
And than maybe something like:
cfValues[‘Internal’] != null || cfValues[‘External’] != null
Robert Dzido _Almarise_
August 22, 2019
Hi @Nikhil
Try using Workflow PowerBox app (if you have Jira on-prem). It has feature called "Validator Templates". you can create a template with 2 validators (one per field) and connect them with "Any of fillowing validators" operator.
Should work:) and you can define your own validation error messages as well.
Unlike ScriptRunners behaviours (great plugin anyway) validators work also when using REST API.
jira guy
August 19, 2019 edited
You can use script runner behaviors to achieve this. https://scriptrunner.adaptavist.com/latest/jira/behaviours-overview.html
No need to write any scripts if you have already have the plugin
First bullet point in the documentation
  • Making a field mandatory depending on other data entered on the issue screen (i.e during an issue creation or an issue transition)
Jack Brickey
I would probably use two different Issuetypes (Internal, External) and have different screen schemes for the two so you could have the appropriate field required.
Another consideration - use a cascading field:
  • Internal
    • A
    • B
    • C
  • External
    • 1
    • 2
    • 3
and make the field required via the create transition validator.
