How to make the field read only on Edit Screen on particular status
Vineela Durbha
I have a field on edit screen and I want to make the field read only only for particular status.
Is there any way apart from behaviors to make field read only in this case
Alexey Matveev
August 14, 2018
You can use also the Power Scripts add-on:
https://marketplace.atlassian.com/apps/43318/power-scripts-jira-script-automation?hosting=cloud&tab=overview
There is the Live Fields feature. You can modify fields in the Create, Edit and Transition Screens.
Your code would look like this:
if(argv["screen"] == "Your transition name") {
  lfDisable("Your custom field name");
You can find more info on Live Fields here:
https://confluence.cprime.io/display/JJUPIN/Live+Fields
Nic Brough -Adaptavist-
August 14, 2018
You don't.  Jira does not have field permissions.
Vineela Durbha
So only way would be only through behaviors?
August 14, 2018
Yes, you need something that will botch it with javascript.
Vineela Durbha
ok Thank you
