How to manage labels?
xinan liu
As the title says, how can I manage labels?
Just like delete the labels I don't want by JIRA administration.
Is that the labels can only be deleted in issues?
Community moderators have prevented the ability to post new answers.
Post a new question
16 votes
Lori Hamilton
Always an "additional" expense for things that obviously should be part of the core product. It's so frustrating as an Admin to not be able to do things that should just "be".
Nic Brough -Adaptavist-
September 11, 2018
It's another feature that Atlassian don't see any need to add to the core (nor do most of us frankly).
If you want a managed list of labels, use a multi-select instead.
Like John likes this
Michael Fasani
November 6, 2018
It should be possible to bulk edit and bulk assign:
Here is an example we suffer from:
Developer A adds the label: widget
Developer B adds the label: Widget
Developer C adds the label: widgets
Developer D add the label: Widgets
Now I have 4 labels which are all the same thing.... I just want to change them all to be widget...
Like # people like this
Lori Hamilton
Let me save you time, the answer is always "pay for another plug in" - Atlassian seems to have no desire to make their product actually useful and every desire to pawn the responsibility for their product off on 3rd parties and ensuring you pay as much $$ as possible to use their product.
Christien Groff
In Jira Cloud you can search for issues with particular labels and use the "bulk change" option to edit/remove/replace labels. Years ago, Jira server also had the option, but at the time, it just replaced all labels in the bulk edit, you didn't have other options. I haven't used a server version for several years now so I am unsure if that feature has been improved or still exists.
Anthony France
@Nic Brough -Adaptavist-
Hey Nic, let me explain why we need to manage the values of the label field; and to make it even easier I'll use your own words.
Nic Brough [Adaptavist] COMMUNITY CHAMPION Nov 21, 2013
No. Multi-select list options are set by the administrators.
You'd need to write a new field to do this. Or do it the slightly easier way and simply use a labels field - not quite a drop down, but has auto-suggest and let-user-add-random-value to it.
https://community.atlassian.com/t5/Answers-Developer-Questions/Is-it-possible-to-add-values-to-a-quot-select-multi-select-quot/qaq-p/475192
So; this is exactly what I was looking for a multi-select with the ability to allow the users to add; and I decided a label would work based on the above.  And then I tried to pre-populate the new custom label field and couldn't figure out how to do it when I came across this topic.
Looks like we've come full circle?  Could you maybe start to see the why it might be a "good thing" that admins can manage labels?
Alessandro Tondo
This is certainly not an answer to the question, but it can be an easy workaround to get a "hybrid label/multi-select" item.
We have used the following condition in a ScriptRunner Behavior to set up a labeled custom field which handles our product serial numbers.
They have a predefined structure and are suitable for regex filtering, but one can adapt it for example to forbid extra-long labels.
def formField = getFieldById(getFieldChanged())
def serialNumbers = []
if (formField.getValue() in String) {
serialNumbers.add(formField.getValue())
} else {
serialNumbers = formField.getValue()
formField.setAllowInlineEdit(true)
formField.setFormValue( serialNumbers.findAll { it ==~ /^(0\d{2}){2}\d{4}$/ } )
log.debug("Serial Numbers : " + serialNumbers)
Like Stephen Hayden likes this
14 votes
Daniel Dhillon
June 24, 2018
This should be a feature that admins can use.  Scenario: a developer decides to take the time and add "a very long label to any number of issues", since labels are displayed alphabetically, this label can block off the UI and since we can't adjust the width of the issue details while on the sprint screen, this makes for a very unhealthy user experience.
Nar Kumar C. - Narva Software
Hi Daniel,
In order to fix that problem, you can use our app Label Manager for Jira Cloud
It allows managing labels per project or globally. It gives full control over your labels. You can rename, delete or merge labels. It's currently available for cloud.
Try it out from Marketplace: https://marketplace.atlassian.com/apps/1221542 and let us know if you face any issues.
3 votes
May 17, 2015
Yes, you can only "manage labels" via issues.  Labels are not intended to be "managed" centrally, they're for users.  If you want to use managed lists of words/phrases, then use a multi-select field instead.
xinan liu
Batchen Eden
January 24, 2017
I'm pretty new with Jira..by multi select field so you mean a custom field?
how do I create one...?
thanks!
@Nic Brough [Adaptavist]
January 24, 2017
Yes - as an admin, go to issues -> custom fields, and click "add".  Answer the initial questions about name, starting content (options) and screens, save it and you'll have the field on your issues.
To add/update/de-activate/delete options later go back to admin -> custom fields, and change the config of the field
Nicolas Sigalo
February 6, 2020
Just use bulk edit with an appropriate search. This is why Jira will never have that feature : you can already do it in a very simple way.
And keep in mind : if managing labels in your Jira is time-consuming, maybe you not using it in the right way ;)
Anthony France
Can you describe in detail how to delete a label using your process?
Christien Groff
In Jira Cloud:
  1. do a search for your isssues
  2. select all or a sub-set
  3. use the ellipsis in the top right and select "bulk change all X issues"
  4. veryify those are the issues you want, click next
  5. select edit issues, click next
  6. scroll down to "Change Labels" and select it and choose the option you want in the dropdown, and enter the label names you want, click next
I haven't used Jira Server in several years so I am not sure if the process is the same.
@Anthony France
codecentric AG September 1, 2016
There is a way to manage labels if you use the plugin "Label Manager for JIRA" https://marketplace.atlassian.com/plugins/rs.codecentric.label-manager-project/server/overview
You as an Project admin or JIRA Admin can manage which items are available project based.
Brian Schussler
This looks like a great tool, I hope it come to cloud too.
Like Thomas Schneider likes this
Saskia Zeedijk
There is a request created to delete/maintain labels. Please vote for this functionality! https://jira.atlassian.com/browse/JRASERVER-33672
Eric Barnes
I think if you need to standardize a "label" or category of some kind, create a custom multi-value field and manage it that way. You will need to update your screens to handle the field, but this would be a much better way to use.  It makes it easy to group like issues and report on verse labels that you don't really have central control and can get cluttered.
Anthony France
This misses the mark unless something else has changed.  The reason for using the label field instead of a select is that users can add labels.
It just so happens sometimes labels need to be managed and cleaned up.
Wade Sturman
has anyone had issues with labels not saving? I add a TEST label to an issue and save --> delete the TEST label and save --> go to re'add TEST label and it doesn't show up under recommended labels.
any ideas?
Christien Groff
It sounds like it is working as intended. The suggestion list that pops up is a list of labels that are currently in use on issues. If you create a new label on an issue, then remove it, and it isn't used in any other issues, it will not pop up in the suggested list.
Joshua Kustin April 16, 2019
@Christien Groff  This is a hugely underrated comment and really the simplest way to get around the problem of managing labels. It would be a manual process obviously and would require upkeep, but probably the only way without the plug-in. Thanks for the information.
Max Muster
May 16, 2019
Nice then simply search the whole project like Michael Fasani for widget, Widget, widgets and Widgets then delete them and do that on a daily base because wrong or stupid labels could be added every second. Delivering an extra Plug In for managing a software which is expensive enough, is very very very sad. You want to get the best out of your product? Then simply dont pay the full price, pay double or triple full price for getting the chance to give colours to your labels! Wow
Joshua Kustin May 16, 2019
@Max Muster You're not wrong - yes, "wrong or stupid labels could be added every second" - but it sounds like that would be more of a "How to manage employees/project standards?" problem. Require or agree on accountability and enforce/support it or enlist the aid of someone or a group of someones that can. Jira allows you to view just about every edit on an issue and the user who did the editing, including editing of a label.
Also, it becomes pretty difficult for users to add an erroneous label after the list is populated with accurate labels. Even if the user types "lAbEl", if there is already a "Label", when you hit enter, the existing label is chosen. However, I totally agree there should be a label manager built in, because honestly, why wouldn't there be if you can add labels?
Like Pedro Silva likes this
Tomi Bates
December 4, 2019
Thank you @Christien Groff that helps a lot!
Like Christien Groff likes this
Post a new question
