How to map Jira For Testing Life Cycle.
Jemy February 20, 2013
Hi All,
My Organization looking further to Use Jira for Testing and Development Life cycle.
We can customized jira through workflow Transitions.
i will be apreacite if i will get the list of plugins i can use to make Testing life cycle complete for jira.
please let me know your suggections.
regards,
sam.
tousifs
March 24, 2013
Hi Sam,
Jira It-self you can use in 'SDLC' and 'STLC' life cycle management.
Via work flow you can defined process.
I can suggest you to go for customized plugin for reporting and Transitions which could help you to achive target.
regards,
tousif shaikh.
Avdhesh Chauhan
February 24, 2013
The basic JIRA suite utilities, Workflow extenstion plug ins should help - bcz all we will be doing it to create sub task and copy/ swap values between parent issue and sub task - so these two should be fine
Get Certified! ✍️
