How to map my already existing test scripts with xray test cases.
yaminipriya harikrishnan
May 9, 2022
We already have a set of test scripts written. We introduced Xray recently how to map the xray TC's to the existing Test scripts? can someone help on this?
Sergio Freire - Xblend
June 2, 2022
@yaminipriya harikrishnan
a) Your test scripts are implemented using which programming language and which testing framework? The answer depends on that.
b) Can you please also clarify if you're using Xray on Jira server/datacenter or instead on Jira Cloud?
Stefan Salzl
Hi @yaminipriya harikrishnan and welcome to the Atlassian Community,
Could you please specify your requirement a bit more in details?
- Which scripts did you write?
- What do you mean by "map"? Please keep in mind that XRAY is a test management tool and not a testing framework or a native test runner.
Please let the community know what exactly you are trying to accomplish and where you are struggling.
Best
Stefan
Stefan Salzl
Hi @yaminipriya harikrishnan ,
Any feedback/further input from your side regarding this issue?
Best
Stefan
