How to migrate ALM to jira
Thirupathi Gangula February 5, 2024 edited
We are planning on bulk migration of multiple projects from ALM to JIRA. Would like to know if there are any ways to migrate the below data from ALM to JIRA Have anyone worked on such migration before, if so can you share the best way/process steps.
Hosting type : both server and cloud
Thirupathi Gangula February 6, 2024
We need data from ALM to Jira.
Requirements ( including attachments)
Test Cases ( including attachments)
Defects ( Including attachments)
Is there any utility available migrate project from ALM to Jira?
Trudy Claspill
Hello @Thirupathi Gangula
It has been several years since I worked with ALM. At the time it was still owned by HP.
Which features of ALM do you use? Are you needing to migrate test information (test cases and/or test execution results)? Are you needing to migrate issue tracking?
Are you planning to use native Jira functionality, or will you add a third party application that adds functionality for test management?
One option for you to consider is engaging with an Atlassian Solution Partner to help you with the migration effort. Many partners already have executed such migrations and can analyze your environment and work processes to make recommendations on the best path to follow.
(Disclosure: I work for Praecipio, an Atlassian Platinum Solution Partner.)
Other options are to use a basic CSV export to get data out of ALM, and CSV import to import the data into Jira Cloud.
If you incorporate a third party app that extends Jira with Test Management functionality, there may be additional migration options available.
Register today
