Anybody here has any idea about any tool that can do full migration from HPQC to Zephyr in Jira? (I can only HP ALM adapter for Zephyr)
Otherwise anyone has any idea how it can be done manually to import HPQC project into zephyr as exactly with same content one by one?
Quick help will be appreciated.
What version of HPQC do you have? There's a native API to bring some of the data over if it's 7.5x (unsure of exact version) or greater
Also, I'm assuming ZEphyr App on Jira not their enterprise product? Not all the components may get migrated (e.g. fields/Reuquirements).
We've done it as an integration through Exalate, https://exalate.com/ (we're a partner).
If you can get CSV files or leverage the API, that's probably the easiest. Extracting out of HPQC if you have older versions is probably the most challenging. If you need to expand on the Jira side, you can look at using X-ray.
Hi Josh- the hpqc version is 11.xx and jira is 8.xx.
yes ur assumption is correct I am talking about zephyr plugin for Jira not the enterprise one.
Though I know the manual process will be bit heavy and non-feasible piece but is it possible for time being? Any link with the steps kr document you have?
jira xray plugin can help to migrate the whole content of hpqc and map into zephyr?
