Hello all,
I am new here and I need help with an issue.
I have 2 workflows under 1 workflow scheme. The scheme is used by 3 different projects.
I need to migrate Story & Task issue types from "JIRA Workflow" to "Defect Tracking Component driven workflow", as you can see in the photo.
I would like to know if this kind of change is going to affect all the 3 projects that are under this workflow scheme or there is a way to avoid that (except for create a new workflow).
You should edit the Workflow scheme and attach the Story and Task issue types to the Defect Tracking Component driven workflow. After it you will apply changes and then all Epics and Stories will be converted to the new workflow.
It will affect all your 3 projects.
@Alexey MatveevIf he doesn't want it to affect three project he has to make a copy of the workflow scheme or create new one and associate workflow with issue types and then use it in one of these 3 project!
@Iro KaravasiliJust make a copy of Workflow scheme, then once logged in as JIRA admin, go to Admin button > Issues > Workflow schemes , it will be under inactive click the arrow, there you can associate issue type with workflow which you have added/assigned by "Editing" the scheme.
Best!
Register now
