Hi , We are migrating out JIRA projects to a different JIRA which does not have Service desk. Is there a way to convert a service desk to normal JIRA project.
Sateesh
Sateesh, certainly you can create a project and import. The documentation does a good job of explaining how.
If you have JSD projects that you want to change to JSW this can be done in each project > project settings > details - change the project type there.
We are still at JIRA 6.1. The plan is to migrate to JIRA 6.4 without service desk. Can I create a new empty project in the destination JIRA and perform a csv import.
If you do that, what happens to the data in fields that are Service Desk specific (e.g. Customer Request Type)? Is this data removed from the issues?
Link to the appropriate doc: https://confluence.atlassian.com/jirakb/how-to-remove-or-disable-a-service-desk-777027025.html
Generally, you will find the documentation covers these common scenarios.
Register now
