I've added a Jira project subscription to one of the public Slack channels. Now I want to modify the subscription to reduce the notifications. How to do that?
Hi, Sandeep.
You will be able to modify the notification settings according to the following screen under Project Settings >> Slack Integration:
Please untick the checkbox(es) according to your preferences and let me know if that helps. Thanks.
