How to modify the JIRA mail sender's name
yuan xingyang February 6, 2012
JIRA MAIL default the sender form is xxxx@gmail.com;I want the recipient to see the sender is the "JIRA Server";What solution can be.
Dipti Ranjan Behera
January 15, 2013
In general configuration section of Jira , you have 'EMAIL FROM'.
here you can put ${fullname}
Mathiyalagan
May 15, 2015
Hi All,
     Could please any one help me to fix this issues.
We have changed email server and updated outgoing email config. After this changes all emails not adding user fullname at prefix of emails sender but my instance "Email From" is remains same "${fullname} (JIRA)"
Old: Mike Nike (JIRA)[jira@xx.com]
new:jira<jira@xxx.com>
guillaume michaud
September 20, 2017
  I had this problem too.
in System, Outgoing Mail, changes the From address to an address not known in the office address book
Like Ivan Kulchytskyi likes this
Christian Czaia [Decadis AG]
February 6, 2012
You can change these things in Administration-->Outgoing Mail Servers
Just type "g+g" when you are in the Administration Tab and search for Mail
Christian
yuan xingyang February 7, 2012
Hi Christian
Thank you for your answer,but not the answer I wanted.Is the name of the sender that I want is "JIRA Server",not the message subject is "JIRA Server".For example
sender subject .......
JIRA Server ...... .......
Like Tat'yana likes this
guillaume michaud
September 20, 2017
 it's been 5 years but I've had this problem also lately.
in System, Outgoing Mail, changes the From address to an address not known in your office address book
after that in system, settings, Email From will display the right thing $ {fullname} or $ {email}
Keith Howard June 10, 2013
Ours is formatted as ${fullname} (JIRA).
It's been sending emails as User Name (Jira) as long as we've had it and suddenly it's only sending them as Jira.
Should I try re-entering the formatting. Does it matter if it's entered as ${fullname} or can I just say $fullname (JIRA) ?
February 7, 2012
have you tried editing the "Email from" paramerter in General Configuration?
Specifies the From: header format in notification emails. Default is of the form "John Doe (JIRA) <jira@company.com>". Available variables are '${fullname}', '${email}' and '${email.hostname}'. Note that the actual address (e.g. 'jira@company.com') cannot be specified here - it is determined by the mail server or individual project configuration.
http://confluence.atlassian.com/display/JIRA/Configuring+JIRA+Options
Hi Christian
I have been trying to set ${email.hostname}and ${email},but no results.
February 7, 2012
What do you mean with no results, what does the email you are getting look like? I thought you might just want to add something like (Your Company JIRA server) or replace the $fullname with (JIRA Server).
Hi
No results mean is that mail does not seem to any changes,and I have been using the string "JIRA Server" to replace the $fullname,the mail still does not any changes!
February 7, 2012
Odd, I just replaced the $fullname with "JIRA Server" and I got the right header
anfield leung April 16, 2015
Is it possible to change the name dynamically with the actual address? e.g. ABC <abc@xxx.com>, XYZ <xyz@xxx.com> ?
Scott Kerr
November 3, 2015
What's the answer for 6.4? I tried setting the prefix to '${fullname} (JIRA)' (no quotes) and it came back '{$fullname} (JIRA)' (no quotes), instead of using the currently logged in user name.
February 6, 2012
You can change these things in the Administration-->Outgoing Mail Servers
Get Certified! ✍️
