How to move issues with the post function in "jira" creat?
Sema YILDIRIM
How to change issue type according to custom field value with post function in "Creat" step?
Leonard Chew
January 16, 2020
You could do that with a scriptrunner postfunction, but the better approach would be to set up your process so that the correct issue type is set at creation (i.e. without needing to change it).
Sema YILDIRIM
Thank you but How to change issue type in post step with Post Function?
Leonard Chew
January 16, 2020
Although it's only the issue type and not status and workflow: When reading other posts about this topic, it is clearly not wise to change the issue type at creation, and it might not work on a post function.
https://community.atlassian.com/t5/Marketplace-Apps-Integrations/how-to-change-issue-type-and-workflow-programmatically-via/qaq-p/599444
Like Sema YILDIRIM likes this
Sema YILDIRIM
thank you
