The order of actions is determined by the weight attribute. The JIRA standard actions are available in the WEB-INF/classes/system-issueoperations-plugin.xml.
'Email This Issue' action is from a plugin and to change the weight attribute, you will have to modify the atlassian-plugin.xml of that purticular plugin, re-create the jar and re-deploy it.
Note that you will have to do this every time JIRA is upgraded!
Background on this is at https://answers.atlassian.com/questions/33795/workflow-help
I'm stuck - I remember in v3, you could set the order of some things with numbers in the atlassian-plugin.xml, but I've not looked in 4.
