Hi everybody!
I have a code that, when the status changes, transmits field values in Json format to another service, the code works fine, but there is a problem with passing an array of field values, now all values are transmitted as a string. How can I pass the values of a multiple choice field in the format ["1param", "2param", "3param"] ?
I will be grateful for any help
I managed to solve this problem using JSON array:
I can't tell exactly where you're trying to set multiple values to the same field in your API call, but I found a post that had code that seemed to work for some users:
https://community.atlassian.com/t5/Jira-Software-questions/How-to-save-values-to-a-multiselect-field-using-the-rest-API/qaq-p/1524820
Below seems to be the basics of what they included:
"fields":
{ "customfield_11201": [{"value": "Disclosure"},{"value": "SecondValue"},{"value": "ThirdValue"}]
Thank you, this is not exactly what I needed, I managed to solve the problem using JSONArray.
