How to populate a custom field based on another custom field value?
Sakshi Mittal March 26, 2018
I am trying to populate a custom field B(single select drop down) based on value from Custom field A(multi-select drop down).
I want this to be done on the create issue screen.
If the value of field A is 'a' , the values to select in custom field b should only display x, y
If the value of field A is 'b' , the values to select in custom field b should only display l, m
I am not sure if this has been answered before. Atleast i could not find it.
Your help would be appreciated.
Best Regards
Sakshi
Sakshi Mittal March 28, 2018
Thanks Shawn. I installed the plugin but cannot find the option to set the conditions on the fields.
Could you give me an idea about how you implemented it?
Regards
Shawn Masters
March 26, 2018
We accomplish this by using the following addon (they have a free version 'Lite' as well with limited functions)
https://marketplace.atlassian.com/plugins/com.codebarrel.addons.automation/cloud/overview
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
