How to populate a custom field select list with multiple choices
Karina Green June 4, 2021
I am creating a new issue via a script in scriptrunner. I am trying to populate a customfield select list with 2 options, I not sure what I need to do to set custom field values to populate the 2 options  in this code, any help would be great.
def location = customFieldManager.getCustomFieldObjectByName("Location")
def fieldConfigLocation = location.getRelevantConfig(issue)
def optionLocation = optionsManager.getOptions(fieldConfigLocation).getOptionForValue(["ODC, RDC"], null)
issue.setCustomFieldValue(location, [optionLocation])
Vikrant Yadav
Hi @Karina Green
Try below code to populate Select list field value according to issue type selection :-
Please make sure value which you want to populate must be added in select list field.
import com.atlassian.jira.issue.*
def issuetype = getIssueContext().getIssueType().name
def selectcf = getFieldByName("Sub-type")
selectcf.setFormValue(null)
def optionsManager = ComponentAccessor.getOptionsManager()
def customField = customFieldManager.getCustomFieldObject(selectcf.getFieldId())
def config = customField.getRelevantConfig(getIssueContext())
def options = optionsManager.getOptions(config)
if (issuetype.contains("Story")) {
def optionsMap = options.findAll {
it.value in ["Custom Requests","Survey Project Management","Proposals"]
}.collectEntries {
(it.optionId.toString()): it.value
selectcf.setFieldOptions(optionsMap)
else {
it.value in ["Job Matching Assistance Only", "Standard Data Extract","Job Matching and Data Extract","Prevailing Wage"]
}.collectEntries {
Vikrant Yadav
I forget to add classes :-
Correct Script --
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.CustomFieldManager
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
}.collectEntries {
else {
}.collectEntries {
Register here ⬇️
