How to prevent a page "freeze" after a ScriptRunner post function?
DanielG
September 30, 2017
I have a post function which moves the issue depending on the value of a custom field.
The script works successfully, but every time the post function runs, the screen remains greyed out until the browser is refreshed.
Is this a common problem? Is there an easy way to make sure the page is visible after the transition? Is there a timeout?
Thanos Batagiannis [Adaptavist]
October 2, 2017
Hey Daniel,
This does not sound right.
Do you use the fast track transition built in post function ?
Do you get any errors in your logs ?
JIRA and ScriptRunner versions ?
Regards, Thanos
