I have two custom user picker fields, "Defect Owner" and "Assisted" and both default to user "sfederman" when an issue is created. I need to create a rule that prevents users from progressing the ticket if sfederman is still listed in this field.
So i scripted this as a validator but it doesn't seem to be working. The issue transitions just as it normally would.
The Scriptrunner documentation may be of a better help. I must admit I haven't used the scripted rules much, and I'm not knowledgeable in Groovy. There might be a simple syntax mistake in what I gave you. I based my suggestion on the examples given.
Have fun!
Create a validator. You can do that with various plugins (mine is JJUPIN, but you can use ScriptRunner, etc).
