How to put Velocity parameters in WebWork action
grundic
September 19, 2011
I've implemented custom WebWork action. For it I've supplied some velocity templates.
How can I add custom parameters to velocity? I didn'f find any such method :(
Jobin Kuruvilla [Adaptavist]
September 19, 2011
If you add private variables in the action and getter methods for them in the action class, they are accessible from the velocity template. Is this what you want?
grundic
September 19, 2011
Yep, I think that's just it! Thanks a lot!
grundic
September 19, 2011
One more question: if I have to add to velocity context standard jira components - for example, webResourceManager - should I write something like:
public WebResourceManager getWebResourceManager(){
return ComponentManager.getInstance().getWebResourceManager();
It looks like overhead :-/
Bahar Çağlar
Hi Jobin,
Can you give an example for this?
October 11, 2012
Example for getter/setters? If you have variable xyz and getter/setters for it, you can access it in velocity template as $xyz
October 11, 2012
Are you missing 's'? Try
<p>size : $crman.relationSchemes.size() </p>
You can also use
<p>size : $crman.getRelationSchemes().size() </p>
Bahar Çağlar
I can access with action like
#set ($crman = $action.relationManager)
then, I want to access its variables as folows:
<p>size : $crman.relationScheme.size() </p>
I have a getRelationSchemes() methods in it, but I am always getting zero. What is wrong with this?
