×I have a requirement to present a Issue Collector queue as a dashboard gadget but don't know how to query for issues created by a specifice issue collector. How do I reference the collectorid in JQL?
Thanks for any help.
Hi Bruce,
--I'm afraid that this is will not be possible as the labels field that gets the collectorid is not seachable like that.--
Scrach that. What you can do it to use the JQL for the environment field:
environment ~ "location user-agent referrer"
Of course, this will also get other issues that are might have the data already or that is entered manually, but it's an alterntive.
You can use a custom field (https://confluence.atlassian.com/display/JIRA/Advanced+Use+of+the+JIRA+Issue+Collector) to set a specific value to the issue which you can then query against.
Gentlemen,
I ended up adding new unique environment variable, and that did the trick.
environment : { 'Custom env variable' : 'hidden_value' }
Now a simple text search returns all the issue collector issues. I may simply replace that value with Issue collector id and achieve the same result.
Thanks for guiding me in the right direction.
