How to query Summary for EXACT match?
Timothy Harris
Sio I want an exact match when using the contains operator in a JQL query.
key = TEST-36 AND summary ~ "__SPU__"
However this seems to return anything with SPU also regardless of capitalization!
How to get an exact match?
4 votes
Thomas Schlegel
May 18, 2017
Hi Timothy,
this is not possible with current Jira versions. There is an open issue for that:
https://jira.atlassian.com/browse/JRASERVER-21372
Maybe you want to vote for it.
Timothy Harris
sigh...
OK, well since I am calling it from script runner then I can use a regex to make sure it matches.
But it is really irritating that the issue referenced has been open for 7 years. This should be supported by JQL :-(
Thanks for the reply!
Like Judith Richards likes this
Bilal Ahmed
August 2, 2017
I have the exact requirement. Timothy, can you please elaborate on "calling it from script runner".
Kabeleced April 27, 2022
Should not the accepted answer - took me unnecessary time to read everything here to finally find (at least for me) the working solution further down.
30 votes
Brian Desany
I love how this entire community is filled with posts that describe an issue, and they are all "solved" with the solution being "you can't do that".
Alex Koffler
I wish I could upvote this 1000x more
Like # people like this
Anton Ukhanev
@Alex Koffler , you can't do that.
Anton Ukhanev
The anthem of Atlassian :D
Like Grigory Salnikov likes this
Ram
August 24, 2020
seems like escape quotes work. summary ~ \"XYZ\"
Georgi Mitov
September 5, 2023
As of Sep 2023 - there is "kind of" a solution for Jira Cloud:
use: summary ~ "\"search string\""
(described here: https://community.atlassian.com/t5/Jira-articles/Search-for-an-exact-phrase-with-JQL/ba-p/2131545)
How usable is this - is another topic. But at least there is a solution!
Like Juan Martín Bortolazzo likes this
5 votes
kyona
Hello everyone,
scriptrunner JQL function helped me solving that issue
issueFunction in issueFieldExactMatch(subquery, fieldname, regexp)
took from here
https://jira.atlassian.com/browse/JRASERVER-21372?focusedCommentId=2619612&page=com.atlassian.jira.plugin.system.issuetabpanels:comment-tabpanel#comment-2619612
Julian from AF
Hello thank you solved for me !
Joshua Hopkins October 21, 2021
@Julian from AF
I have been reading documentation for days now trying to get scriptrunner setup. Any advice to help me get it working?
Julian from AF
Hi @Joshua Hopkins ,
Yes see my screenshot :
In my case i use it in Jira Automation and it's working fine.
To help you, you can use the website https://regex101.com/ to construct your regex if you need more than an exact match. To have an exact match, just put your text between ^and $ as shown but with regex101.com you can construct more precise.
Is it clear for you?
Julia
Can someone help me understand why this query returns 16 tickets (14 of which are an exact match), but the below scriptrunner query does not work? Screen Shot 2022-07-26 at 11.51.36 AM.pngScreen Shot 2022-07-26 at 11.52.22 AM.png
Julia
Update: this worked. issueFieldMatch worked for me and not issueFieldExactMatch
Like Julian from AF likes this
