How to query by ticket number range
nathanwendling
June 9, 2017
Trying to figure out how to get all tickets in a range, e.g. if the tickets are for project abc and issue numbers 400-410 all need changes, can I at least query a list where I only see abc-400, abc-401, ..., abc-410?  something like 'project="abc" AND *unknownFieldName* > 409 AND *unknownFieldName* < 411 ORDER BY *unknownFieldName* DESC' ?
11 votes
Deleted user June 9, 2017
Use the issuekey:
issuekey > ABC-409 AND issuekey <= ABC-411
nathanwendling
June 9, 2017
Thanks, didn't realize that those were allowed on strings in JQL, after all the trouble I had earlier trying to use ~ on things.
js-shm
April 12, 2019
Russell Warren
This does not work (at least currently) if one of the keys used n the limit does not exist.
For example:
issueKey > ABC-409 AND issuekey < ABC-411
will not work at all if either one of `ABC-409` or `ABC-411` doesn't exist either (has not been created yet, or has been deleted).
Like # people like this
Mark H_ Williams February 20, 2020
I switched the AND to OR and it worked
Lynne Randolph
moved to answer to clarify
