How to receive webhook in python flask
wisehq123
June 23, 2017
I build a webhook for issue update,also added it to workflow.
Now the problem is I want to write an API in python(flask) to retrive the webhook data and dispaly it.
Below is screenshot of my webhook.Thanks
somethingblue
June 23, 2017
Hi wisehq123,
I don't have a specific article about Flask and JIRA, however, the good folks on the Bitbucket team created and article titled Tutorial: Create and Trigger a Webhook.  While it's for BitBucket it does go over how to use a Flask server that receives webhooks.
You should be able to modify this for JIRA.
Branden
wisehq123
June 23, 2017
Thanks buddy:)
kz1212 October 5, 2017
Hi @[deleted],
Do you know if there is any tutorials forWebhook using python in windows? the one above is for MacOS.
thanks!!!
