How to refer date picker in Cascade field ?
Alik
Hi all,
I want to refer date picker field in my multi cascade custom field. How can I choose date/time in multi level cascade field and how I can write query in SQL?
For example I have date picker custom field and I want to refer it in SQL query. In atlassian SQL developer documentation I can't find any information how SQL store dates in date picker (no information about tables). I don't want to show list of dates for choose I need to give date picker field inside of multi cascade field.
I think query will be similar like this
select datevalue from customfieldvalue where customfieldconfig=10501;
Documenation
https://developer.atlassian.com/server/jira/platform/database-custom-fields/
Thanks in advance,
Alik
Earl McCutcheon
March 10, 2020 edited
Hello again @Alik ,
This post looks related to the other post you had I answered recently, where unfortunatly a dynamic date picker cannot be used as an option in a cascading field, only static values, viewable here for a referance point incase anyone else runs into this post with a similar questions.
But to elaborate a bit on the rest of this question relating to the DB table layout for the field options for a cascading field,  The tables that store the field options is going to be "customfieldoption"  table, and you can look at the table using:
select * from customfieldoption where customfieldconfig=<CUSTOMFIELD_ID>;
Earl
Alik
Hi @Earl McCutcheon ,
Thanks for your answer again. You are right this is same question related with cascade field.
Alik
Like Earl McCutcheon likes this
