×Hello,
It is possible to remove the "create another" when you want to create a ticket please :
any script natif or with scriptrunner to do that.
Please help.
BR
Fayçal
Hi @BYA ,
There is no feature to disable this option but just in case you want to do it you can insert custom css or JS using ScriptRunner or in the announcement banner. Try this code in the announcement banner.
<style type="text/css">
input#qf-create-another {
display: none;
label.qf-create-another {
display: none;
</style>
Ravi
Hello @Ravi Sagar _Sparxsys_
Thank you for your answer.
I am really beginner to script runner. I go to administration --> manage applications --> Scriptrunner --> Fragments --> Create Script Fragments -->Install web resource
I have this dialog
Can you help me fill in the items to solve my problem and put the code you gave me previously please ?
BR
Fayçal
The css Ravi posted goes to Announcement banner, as Ravi said.
Just paste that style to announcement banner, that's it, there's no need for script fragments or web resources.
Hi @BYA
As @Radek Dostál mentioned the css I posted will go as it is to the announcement banner. If you have ScriptRunner then even better, because you will have option to limit the style to a specific sections.
I made a video on doing exactly that. It will require some changes in yourJVM arguments in your setenv.sh/bat and will require a restart of Jira service because you have to specific resource location where the CSS/JS script will go.
I hope it helps.
Ravi
There's no way to do it, you'd need to hack the core code.
I would ask why you want to do this downgrade? When people have a set of stories to raise, it's a useful option.
I think a javascript could hide it (albeit probably tricky with observer for added elements and whatnot), but I agree, why downgrade it.
