I use jira 4.4.5 and 4.4.1, need to add a radio button with 'Yes' or 'No' values.
But, in the create issue screen this field has another value 'None', guess jira adds it by default.
How to get rid of these value 'None' ?
Thanks, Vishnu.
this worked for me quite well
I solved this by:
Now the "None" option should disappear. I figured it out from here: https://community.atlassian.com/t5/Jira-questions/Remove-the-quot-None-quot-option-from-radio-buttons/qaq-p/297024
Uhm. How though?
Nevermind. I figured it out and posted it.
