You have to change the custom field context configuration and remove the project "JIRA Test Project" fro the context.
Issue Matrix does not take into account the screen configuration.
Thank you for the fast answer, it works. Do you thought about it to implement the screen configuration as it is by another custom fields in jira? In this case we can not use global context.
