How to remove null in Cascading select?
Maridel Gaffud
June 20, 2012
This is the code im using to get the value in CustomField:
$issue.getCustomFieldValue("customfield_10070") or
$customFieldManager.getCustomFieldObject("customfield_10070").getValue($issue)
it gets the CustomField value but it has a {null=} or {null=" ", 1=" "}.
Sample:
{null=Cloud9, 1=Web}
Im using velocity, this code is for notification template.
how to remove the {null=" ", 1=" "}?
The CustomField is a Cascading Select.
Help!
Nino Kienberg March 20, 2015
Hey all,
i've build a separate field-template for cascading select fields. Just replace the XXXXX with your customfield-ID and in your mail the content will be displayed like "ParentValue - ChildValue".
#disable_html_escaping()
<tr>
	<th>$stringUtils.leftPad($issue.getCustomField("customfield_XXXXX").name, $padSize):</th>
	<td>
		#set ($customfield=$issue.getCustomFieldValue("customfield_XXXXX"))
		#set ($start_par=$stringUtils.indexOf($customfield.toString(), '='))
		#set ($start_par=$start_par+1)
		#set ($start_child=$stringUtils.lastIndexOf($customfield.toString(), '='))
		#set ($start_child=$start_child+1)
		#set ($ParentValue=$stringUtils.substring($customfield.toString(), $start_par, $stringUtils.indexOf($customfield.toString(), ',')))
		#set ($ChildValue=$stringUtils.substring($customfield.toString(), $start_child, $stringUtils.lastIndexOf($customfield.toString(), '}')))
		$ParentValue - $ChildValue
	</td>
</tr>
This works atleast for 6.3.8.
Linda H September 19, 2018
Nino,
OMG...Hours to find this and it works in 7.6.1.  Yippie!!!!   You just made my day!!!
Thank you, Thank you!!
Anand Unadkat
December 10, 2014
<% out << issue.getCustomFieldValue(componentManager.getCustomFieldManager().getCustomFieldObject("customfield_XXXXX")).values()*.value%>
<br>
Anand Unadkat
November 25, 2014
I have tried @Aaron Roddis code but I get the following error:
No such property: value for class: groovy.lang.Binding
Any ideas how to parse cascading select list without null?
Aaron Roddis
October 24, 2013
Hi all, ive just used this to select the second string in a Cascading Select. with Version 6.0 of Jira
#set ($value = $issue.getCustomFieldValue("customfield_10000").toString())
#if ($stringUtils.isNotBlank($value))
#set ($childValue=$stringUtils.chop($stringUtils.substringAfterLast($value,'=')))
#if ($stringUtils.isNotBlank($childValue))
$textutils.htmlEncode($childValue)
#end
#end
Nelly Le Texier
July 14, 2013
I found a temporary solution (for example in a templates/email/html/includes/fields/myCustomField.vm):
##Example $value: {null=Foo, 1=Bar}
&lt;tr valign="top"&gt;
    &lt;td style="color:${textColour};font-family:${textFontFamily};font-size:${textSize};padding:0 10px 10px 0;white-space:nowrap;"&gt;
        &lt;strong style="font-weight:normal;color:${textSubtleColour};"&gt;My Field:&lt;/strong&gt;
    &lt;/td&gt;
    &lt;td style="color:${textColour};font-family:${textFontFamily};font-size:${textSize};padding:0 0 10px 0;width:100%;"&gt;
    &lt;/td&gt;
    ##display "My Field: Bar" only
&lt;/tr&gt;
#end
#end
Nelly Le Texier
July 11, 2013
Is there a workaround for the 5.1 version? Indeed, the function "getFirstValueForKey("1")" returns empty.
Thanks.
Frank Adam May 3, 2013
I met an Atlassian person at last year's conference, and here is what he told me:
#if($issue.getCustomFieldValue("customfield_10000"))
#set( $cfValue = $issue.getCustomFieldValue("customfield_10000"))
$cfValue.getFirstValueForNullKey() - $cfValue.getFirstValueForKey("1")
#end
(replace customfield_10000 with an id for your custom field in both spots!).
This worked in JIRA 4.5, but it's not working in 5.2 right now.
Let's build A Rovo Agent 🤖
Save your spot
