How to remove or disable add-ons for a specific project?
Ken Uehling October 26, 2018
I recently received administrative access for JIRA at my work to create a new Kanban board project for my team. I want to keep everything as clean as possible and noticed that there are a few add-ons within the tickets that I would like to remove. Some of these add-ons are Slack integration, JQL Subqueries etc.
Is there a way to disable these add-ons just for my Kanban board? I don't want to mess up anyone else's board. Thank you.
4 votes
Joe Pitt
Not unless the plugin itself has a way to turn it on/off at the project level.
Chinmaya Behera
September 18, 2023
This can be done , whne you go to Project Setting>App>select your app, most of the apps will have a button to activate/deactivate for the specific project.
Michael diLorenzo
This is not the case.
