How to remove "CLONE -" after cloning
Ronneth Dhanish October 25, 2022
Hey guys, I have difficulty using automation. I tried doing it but it seems it isn't working. I don't want "CLONE -" in the summary of my issue and subtasks after cloning them. Please tell me what am i doing wrong. Thank you.
Tharaka_Hettiarachchi
October 25, 2022
Hi @Ronneth Dhanish ,
1. you need to create a branch rule for parent
2. Then choose edit issue as the new action
Cheers!
Hi, What should be the trigger?
Thank you.
October 25, 2022
Trigger will change according to your requirement. If you want to change the issue summery after cloned issue transition you can select transition trigger
Like Gisele Kakishita likes this
Ronneth Dhanish October 26, 2022
Can you please tell me step by step what to do again? I'm sorry, I'm very new to this and really need help. I just want "CLONE -" not to appear in the summary of my subtasks whenever I clone an issue.
October 26, 2022
You can use Issue Linked trigger. check the attachment
Okay after that, I should create a branch for subtasks?
October 26, 2022
yes create branch rule which triggered only for subtasks
I did it, but nothing has changed. The "CLONE -" is still there.
Okay, it works now, Thank you so much.
Mirko D'Arcangelo
March 15, 2024
Hello people I tried but it does not work for me.
I have got this error
This is the rules-setting
Daryl Marsh
but add in the hyphen with spaces
Like Jan de jongh likes this
