How to remove unwanted suggestions form labels
Himanshu Tiwary May 11, 2022
while typing in a detail in label sec I am getting too many uwanted suggestions I want the suggestion that are present in my dashoard only
Trudy Claspill
Hello @Himanshu Tiwary
Welcome to the community.
The design for Labels type fields is that the label values are shared across all projects in Jira.
If you want a multi-select field that shows only the values relevant to your project you will have to add a custom multi-select field. Note, though, that if you do that only a Jira Administrator will be able to modify what values are available for that field. That is different from Labels where any user can create a new label value.
Learn more
