How to remove watchers from tasks
Yash Gupta July 30, 2021
Hi Team,
My task is to delete attachments from closed Jira issues, but when I delete the attachments it notifies the watchers.
Is there a way to remove watchers from the Jira issues before removing the attachments? More than 2.5k issues are there. Removing from UI is not feasible. I am using curl invocations to get the attachment id and delete the attachments.
Kishan Sharma
If you are using REST API, you need to use the DELETE method on the watchers resource to remove watchers from an issue. Have you tried it ?
Yash Gupta July 31, 2021
@Kishan Sharma but I don't want to lose the contact person for the specific issues. Just wanted to delete the attachments.
Kishan Sharma
May be you can store the watcher in a variable first. Then remove the watcher from the page, delete the attachment, and lastly re-add the watcher (which you have it in variable as a first step)
Like • 2 people like this
Jonas Ekström
July 30, 2021
If you have the app Automation for Jira, you can automate both the removal of watchers and deletion of attachments.
There are action components for "Manage watchers" and "Delete attachments".
I've got implementations for removal of attachments, and that works like a charm.
Hi @Jonas Ekström, I don't have app automation.
Sreenivasaraju P
July 30, 2021
Hi @Yash Gupta,
Please refer below link
https://jira.atlassian.com/browse/JRASERVER-70354
This bug is reported with Atlassian. It is still pending.
As suggested in work around, you can try by changing notification schema.
Hi @Sreenivasaraju P ,
Can you please explain what does changing notification schema means and how to use it?
Register today
