How to rename a filter
loomax February 17, 2020
How can one rename a filter. I can't find any solution apart from savesas an delete.
This is not an option as the filters used in Boards
5 votes
Jack Brickey
In Cloud if you click on the filter and get the results then you should be able to click on Details link at the top of the page and edit the name there. Unsure if server has same or not.
paolo.righetti
March 13, 2020
Filter --> Details --> Edit permissions
As the link name clearly says you may rename the filter name from there. Come on JIRA guys, the UI really sucks
Like • 16 people like this
Paul Bauer
April 22, 2021
Thanks - this worked.  Once you enter "Edit Permissions" in the filter's Details link you can update the name.  But seriously, in "Edit Permissions"?!?   Very much NOT intuitively obvious.
Like • 6 people like this
Pete Singleton
February 17, 2020
You can only rename a filter if you are the owner of that filter.  You can check if you are via the "Manage filters" link.  If you are not the owner your only option is to save it under a new name.
I already saw something -- I can only edit the filters under the item My Filters.
If one uses the search the table looks different and the action is missing.
Question -- Who did design this gui ?
Aaron Cruz
July 18, 2022 edited
In Cloud:
Filters (in navigation) => View all filters => 3 dots in row => Edit
