Hi All,
Please help me to rename the field priority in to severity.
Many thanks,
Sanu P Soman
Can you please share me the correct link ??
The translation page gives you a good clue what needs to be changed. Here is a detailled description how you can change the language jar: https://developer.atlassian.com/display/JIRADEV/Customizing%20Text
I would recommend this add-on https://marketplace.atlassian.com/plugins/com.atlassian.translations.jira.inproduct
It is super simple and easy to use
I did exactly the same as Dieter and it worked like a charm. Just make sure not to use auto replace as the keys contain the word priority as well ;)
Could you please provide me the link for the steps.
Thanks.
Yes, that's why it's more than a bit of work :-)
You have to manually edit the translations files found in: /atlassian-jira/WEB-INF/lib/jira-lang*.jar
It's all described here:
https://developer.atlassian.com/display/JIRADEV/Customizing+Text
(Please don't forget to accept this answer if it solves your issue)
