The Automation Add-on no longer works for JIRA 7 so I'm looking for a new way to do this.
We have a custom date field that sometimes gets set when an issue is resolved. We want the issue to automatically reopen on that day. Any ideas on how this can be accomplished?
Hi Joe,
Not a lot of options for things like this on Cloud yet unfortunately.
Hi Ethan,
we are using the Cloud version 7.2.0-OD-05-030 - I guess we are out of luck then?
Joe
Hi Joe,
Do you have server or cloud?
This will do the job if you have server.
Ethan
Hi Ethan,
which Add-On is that exactly? We have not been using one in the past - our issue is basically getting this task accomplished.
Joe
Hi Joe,
Automation add-on was updated to work with JIRA 7 and works great.
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
