I would like to replace the word in the mail body on the workflow post-function.
For instance, A part of body as the following;
* Dear, Assignee
I would like to replace the "Assignee" to the person who is supposed to be assigned actually.
Is there any way to make it possible?
Please kindly let me know if it would be, and for sure it would be a quite helpful for our operation.
manami
Hi, Daniel
Thanks for your kind advice.
I have submitted the issue on the META-INF KFT.
I am looking forward to the reply.
manami
Hey there again, Manami.
You are most welcome. Glad to be able to help. We believe that Tibor has also shared the detailed answer to the question that you have. Good luck!
Warm regards,
Danial
Hey there, Rakuten.
In addition to posting your question here, I would also suggest you to address the query that you have to the plugin vendor to speed things up on your side:
Hope this helps.
Warm regards,
Danial
