Hi ,
I m developing a sample Active Object plugin ,Regarding this I configure the pom.xml file as follows
(jira version 5.0 )
I got the Build error ( Error building POM (may not be this project's POM)), i m confusing where the mistake has been done
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<br< a="">> <modelVersion>4.0.0</modelVersion>
<groupId>com.atlassian.tutorial.ao.todo</groupId>
<artifactId>aotodo</artifactId>
<version>1.0</version>
<organization>
<name>Example Company</name>
<url>http://www.example.com/</url>
</organization>
<name>aotodo</name>
<description>This is the com.atlassian.tutorial.ao.todo:aotodo plugin for Atlassian Refapp.</description>
<packaging>atlassian-plugin</packaging>
try with this
<?xml version="1.0" encoding="UTF-8"?> <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd"> <modelVersion>4.0.0</modelVersion> <groupId>com.atlassian.maven.plugins</groupId> <artifactId>maven-refapp-plugin</artifactId> <version>3.11</version> <organization> <name>Example Company</name> <url>http://www.example.com/</url> </organization> <name>maven-refapp-plugin</name> <description>This is the com.atlassian.maven.plugins:maven-refapp-plugin plugin for Atlassian JIRA.</description> <packaging>atlassian-plugin</packaging> <dependencies> <dependency> <groupId>com.atlassian.jira</groupId> <artifactId>jira-api</artifactId> <version>${jira.version}</version> <scope>provided</scope> </dependency> <dependency> <groupId>junit</groupId> <artifactId>junit</artifactId> <version>4.10</version> <scope>test</scope> </dependency> <dependency> <groupId>com.atlassian.activeobjects</groupId> <artifactId>activeobjects-plugin</artifactId> <version>${ao.version}</version> <scope>provided</scope> </dependency> <!-- SAL, the Active Objects plugin uses SAL's API for transactions --> <dependency> <groupId>com.atlassian.sal</groupId> <artifactId>sal-api</artifactId> <version>2.4.1</version> <scope>provided</scope> </dependency> <!-- Google Collections, useful utilities for manipulating collections --> <dependency> <groupId>com.google.collections</groupId> <artifactId>google-collections</artifactId> <version>1.0</version> <scope>provided</scope> </dependency> <!-- We're going to write a simple servlet --> <dependency> <groupId>javax.servlet</groupId> <artifactId>servlet-api</artifactId> <version>2.4</version> <scope>provided</scope> </dependency> <!-- WIRED TEST RUNNER DEPENDENCIES --> <dependency> <groupId>com.atlassian.plugins</groupId> <artifactId>atlassian-plugins-osgi-testrunner</artifactId> <version>${plugin.testrunner.version}</version> <scope>test</scope> </dependency> <dependency> <groupId>javax.ws.rs</groupId> <artifactId>jsr311-api</artifactId> <version>1.1.1</version> <scope>provided</scope> </dependency> <dependency> <groupId>com.google.code.gson</groupId> <artifactId>gson</artifactId> <version>2.2.2-atlassian-1</version> </dependency> </dependencies> <build> <plugins> <plugin> <groupId>com.atlassian.maven.plugins</groupId> <artifactId>maven-jira-plugin</artifactId> <version>${amps.version}</version> <extensions>true</extensions> <configuration> <productVersion>${jira.version}</productVersion> <productDataVersion>${jira.version}</productDataVersion> </configuration> </plugin> <plugin> <artifactId>maven-compiler-plugin</artifactId> <configuration> <source>1.6</source> <target>1.6</target> </configuration> </plugin> <plugin> <groupId>com.atlassian.maven.plugins</groupId> <artifactId>maven-refapp-plugin</artifactId> <version>${amps.version}</version> <extensions>true</extensions> <configuration> <pluginArtifacts> <pluginArtifact> <groupId>com.atlassian.activeobjects</groupId> <artifactId>activeobjects-plugin</artifactId> <version>${ao.version}</version> </pluginArtifact> <pluginArtifact> <groupId>com.atlassian.activeobjects</groupId> <artifactId>activeobjects-refapp-spi</artifactId> <version>${ao.version}</version> </pluginArtifact> </pluginArtifacts> <productVersion>${refapp.version}</productVersion> </configuration> </plugin> </plugins> </build> <properties> <refapp.version>2.12.0</refapp.version> <jira.version>5.1.8</jira.version> <amps.version>4.1.4</amps.version>//change it to the your installed sdk version <plugin.testrunner.version>1.1</plugin.testrunner.version> </properties> </project>
Today only! Share what you’re the most excited about for Team ‘25 or just dance out the beginning of a new quarter with us.
Comment the postOnline forums and learning are now in one easy-to-use experience.
