I want to create a cutom filed and it should be accessed by users having Developer Role.
Is it possible? How to configure the filed if it's possible?
I am using JIRA V5.2
Jira does not do "field level security". You have several options though
Your version of Jira doesn't matter here, and you need to be an admin to do any of them
just create new Workflow Action something called like Update Data and add required fields to that action screen and using condition you can restrict to developper role
I don't find this option. But with this Can I make this change permanant for cutom files?
Please note that we are using JIRA version is 5.2.
Save your spot
