How to retrieve custom User Properties in JIRA?
Daniel Micallef
I have added a number of properties to various users (via User>Actions>Edit Properties) and aim to use these properties in a mail handler plugin.
These properties are shown in the User page as per below:
and could also be retrieved from the DB via
select *
  from propertyentry pe,
    propertystring ps,
    app_user au
  where pe.ID = ps.ID
    and au.ID = pe.ENTITY_ID
    and PROPERTY_KEY like 'jira.meta.%'
However I am unable to retrieve these properties using UserPropertyManager (as per below):
UserPropertyManager userPropertyManager = ComponentAccessor.getUserPropertyManager();
PropertySet ps = userPropertyManager.getPropertySet(appUser);
The following output shows that the manually added properties are not displayed:
Collection<Object> keys = ps.getKeys();
for (Object key : keys) {
    LOG.debug("Property key   -> " + (String) key + "; Value -> " + ps.getAsActualType((String) key));
Therefore, how can I retrieve the manually added user properties in my JIRA plugin (Note that this is JIRA 6.3).
Gaston Valente
July 5, 2017
Daniel,
Did you try with UserPreferencesManager?
Hope it helps
Daniel Micallef
Gaston,
Is it possible to print all items and values of Extended Preferences?
