How to retrieve data from database developing plugin?
lpopek November 7, 2018 edited
Hello, Im simply developing CRUD Jira plugin using Atlassian-Sd. I have my application on localhost http://localhost:2990/jira, I created simple projects and issues.
In my class I use Active Objects layer.
Im using for example
public ExampleEntry getID(String id){
return ao.get(ExampleEntry.class, 3);
It's working fine, I have result in my Velocity, but implementing Entity in Jira Api it's a little difficult like. Not like in JpaRepository.
How can I make simple CRUD operations, like get Issue, delete issue, update issue, get list of issue. Thanks for respond
Alexey Matveev
November 7, 2018
How can I retrieve all issues with specified KEY for example XYZ with active objects.
for example
ao.findWithSQL()
or
ao.findAll
