How to return a partial view from WebWork action or command?
Maris Seimanovs
I have some parts of my plugin which are loaded through AJAX on demand. Now there is a problem that although my velocity template for that command does not contain html head nor body tags, still JIRA inserts them automatically when I request it from http://localhost:2990/jira/secure/MyAction!myCommand.jspa?_=1386174672969.
How do I return only HTML structure from my own .vm view and stop JIRA from injecting its headers and body?
Paul Pasler
Thanks you brought me on the right way, I think
<meta name="decorator" content="none">
i what you are looking for.
Maris Seimanovs
After some inspection on default JIRA pages as workaround I did it like this:
<html>
    <head>
        <!-- the following must be present to keep the partial view only.
            at first I tried atl.popup as suggested in the docs, but it did not work -->
        <meta name="decorator" content="dialog">
    </head>
    <body>
The response is now clear from head tags and whatnot, but there are some other lines added:
<div class="jira-dialog-content">
        <div class="dialog-title hidden"></div>
which is not a big deal - I can filter them client side with some jQuery.
Still, I'm not sure that's the "official" way to achieve the desired behavior...
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
