×Hi team,
I am trying to run Jira over https where i have cert files and followed this link https://confluence.atlassian.com/kb/securing-your-atlassian-applications-with-apache-using-ssl-838284349.html, but it's giving 503 error. And i have checked that https certificates are valid and locked with green.
server.xml
<Connector port="8080" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^\`"<>"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" secure="true" scheme="https"
proxyName="global-jira.tafzs.com" proxyPort="443"/>
httpd/ssl.conf
<VirtualHost *:443>
ServerName global-jira.tafzs.comProxyRequests Off
<Proxy *>
Require all granted
</Proxy>ProxyPass / http://global-jira.tafzs.com:8080/
ProxyPassReverse / http://global-jira.tafzs.com:8080/SSLEngine On
SSLCertificateFile /etc/letsencrypt/live/global-jira.tafzs.com/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/global-jira.tafzs.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/global-jira.tafzs.com/chain.pem
</VirtualHost><VirtualHost *:80>
Redirect Permanent / https://global-jira.tafzs.com/
</VirtualHost>
Fayaz
Hi @Jack Nolddor _Sweet Bananas_
I have solved my problem by changing below in /etc/selinux/config:
SELINUX=disabled
And restarted my apache in my centos server:
systemctl restart httpd
Fayaz
Hi and welcome,
Is Apache Httpd reverse proxy in the same machine as Jira is located or in a different machines?
You should change:
To
ProxyPass / http://127.0.0.1:8080/
ProxyPassReverse / http://127.0.0.1:8080/
Supossing both are in the same machine, if not please type the IP of the Jira machine.
In Addition, here is a complete httpd configuration of my PROD env, hope this helps:
<Virtualhost *:80>
ServerName jira.mycompany.com
Redirect permanent / https://jira.mycompany.com/
</Virtualhost>
<Virtualhost *:443>
SSLEngine On
SSLProxyEngine On
ProxyPass / http://127.0.0.1:8080/ connectiontimeout=5 timeout=300
SSLCertificateFile /etc/httpd/ssl/STAR.mycompany.COM.crt
SSLCertificateKeyFile /etc/httpd/ssl/STAR.mycompany.COM.key
SSLCACertificateFile /etc/httpd/ssl/OV_NetworkSolutionsOVServerCA2.crt
</Virtualhost>
Does it work?
Regards
I got an error /opt/atlassian/jira/logs/catalina.out
http-nio-8080-exec-17 ERROR anonymous 735x23x1 - 35.177.238.18 /plugins/servlet/gadgets/dashboard-diagnostics [c.a.g.d.internal.diagnostics.DiagnosticsServlet] DIAGNOSTICS: FAILED
com.atlassian.gadgets.dashboard.internal.diagnostics.UrlSchemeMismatchException: Detected URL scheme, 'https', does not match expected scheme 'http'
at com.atlassian.gadgets.dashboard.internal.diagnostics.Diagnostics.checkExpectedScheme(Diagnostics.java:52)
at com.atlassian.gadgets.dashboard.internal.diagnostics.Diagnostics.check(Diagnostics.java:31)
at com.atlassian.gadgets.dashboard.internal.diagnostics.DiagnosticsServlet.executeDiagnostics(DiagnosticsServlet.java:82)
at com.atlassian.gadgets.dashboard.internal.diagnostics.DiagnosticsServlet.doPost(DiagnosticsServlet.java:58)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:661)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
at com.atlassian.plugin.servlet.DelegatingPluginServlet.service(DelegatingPluginServlet.java:37)
at com.atlassian.plugin.servlet.ServletModuleContainerServlet.service(ServletModuleContainerServlet.java:45)
... 44 filtered
at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:56)
... 13 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 58 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 36 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 5 filtered
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:181)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ReentrantThreadLocalBasedCodeContext.java:137)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(ReentrantThreadLocalBasedCodeContext.java:90)
at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(CustomerContextServiceImpl.java:47)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:174)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:130)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:121)
... 4 filtered
at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:32)
... 8 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 24 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
And after configure, when i tried my Jira link with http:And also when i tried my Jira link with http:
Please let me know what's wrong i did and how to solve it?
Fayaz
Have you correctly Configuring the Server Base URL in the UI?
If you cannot log in to the application, you can also Manually Change The Base URL.
Is this necessary to give context like /jira?
No, application context is optional.
