How atlas-run-standalone Jira with application jira-software?
When using atlas-run-standalone --product jira i cannot add jira-software. Installation fails.
This also does not work: atlas-run-standalone --product jira --plugins com.atlassian.jira.plugins:jira-software-plugin
I need to run jira to test a Bitbucket plugin which iteracts with Jira (Software) via application links.
You need to configure AMPS to activate software o sd:
Hope this helps you
That link explains how to configure a plugin project to start additional applications. However the `atlas-run-standalone` command is used to start a product outside the context of any plugin project.
You need to have a look at the customers/users point of view. Jira Software is a product on Atlassians webpage.
You would assume atlas-run-standalone being capable to run any currently sold product. That the software-part is an application inside a framework/system is an implementation detail and should not affect the capabilities of atlas-run-standalone.
Edit: I guess, you just haven't added the needed application support to atlas-run-standalone with introduction of applications.
Do you have any solutions for this issue?
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
