How to run SQL commands in a HSQL database?
Michał Gawlik
I am using JIRA 6.3.5 and here is description how to do it:
https://confluence.atlassian.com/display/JIRA/Running+SQL+commands+in+a+HSQL+database"
but  I cannot see "$JIRA_HOME/
database" directory.
I only have these:
jira\home>ls
analytics-logs data database.log database.script export log monitor
caches database.lck database.properties dbconfig.xml import logos plugins
Thank you in advance for help
Michal
3 votes
Nic Brough -Adaptavist-
December 22, 2014
You're in the right place, but using a different hsql implementation (it varies if you've used EAR/WAR, the installer, the plain download-and-unpack, built it yourself, or running from the SDK).
Where it says look in $JIRA_HOME/database, you just need to read it as $JIRA_HOME
Michał Gawlik
Thanks Nic, it works!
Register today
