How to search in 'Contains Text' field by Issue Key
CV July 2, 2014
Is it possible to search by issue Key in the 'Contains Text' field??
Marcus Silveira
July 2, 2014
Hi CV,
The Contains Text field will only search for text in the Summary, Description and Comments of the tickets.
If you don't have your Issue Key mentioned in one of these fields, it won't return your ticket.
You could simply use the quick search field at the top-right corner to search directly for an issue key.
Why do you need to use the contains text?
CV July 2, 2014
Hi Marcus,
Thanks for your prompt response, We would like to use one serach field for everything. but seems like JIRA has 2 different search fields which is confusing.
and Quick search doesn't serach the text in Summary, Description and Comments of the tickets.
Please let me know if there is any work around??
Huguette
August 18, 2014
For me, I want to search for a text included in a teststep (tescase). It very usefull when we have to update a testcase.
Register now
