How to send custom email using scriptRunner
Yogesh Mude[Jira]
February 5, 2017
We want to send custom mail to that particular reporter with the attachments on the basis on Department ( Department is nothing but the text CF).
If reporter choose Letters – Address Proof within the Department then it should send the Address Proof file as an attachment.
Tarun Sapra
Since department is a text custom field. Just fetch the value of it
cfValues['Department '] and check if it contains  "Letters – Address Proof " using contains() method.
IN the post-function "send custom email" option then you can select - "Include attachments" - "ALL" to send all attachments or if you want to filter out attachment in section
"Custom callback attachement" you can filter the attachements you want to send
like here - https://answers.atlassian.com/questions/18811112.
Yogesh Mude[Jira]
February 6, 2017
HI @Tarun Sapra,
I have used the following script code
cfValues['Department']?.values()*.value == ['Letters', 'Address Proof']
and i got the below error
2017-02-06 11:12:41,255 ERROR [utils.ConditionUtils]: *************************************************************************************
2017-02-06 11:12:41,255 ERROR [utils.ConditionUtils]: Condition failed on issue: null, built-in script:com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.SendCustomEmail
groovy.lang.MissingMethodException: No signature of method: java.lang.String.values() is applicable for argument types: () values: []
Possible solutions: valueOf([C), valueOf(boolean), valueOf(char), valueOf(double), valueOf(float), valueOf(int)
	at Script42.run(Script42.groovy:1)
2017-02-06 11:12:41,269 ERROR [utils.ConditionUtils]: Script follows:
Tarun Sapra
You said in your question that it's a text CF and not a list, the script you wrote is for a list of values and not a single text field.
Yogesh Mude[Jira]
February 6, 2017
can you help me here to write Text CF script code.
Tarun Sapra
cfValues['Department']?.contains(<your text>))
You can try the code first in the "script console", script runner plugin in the admin section has a script console and in that you can try the code. In the admin section of the plugin, search for "script console" and try the code there
Yogesh Mude[Jira]
February 6, 2017
As you told earlier i have been tested the below code
def cfValues
cfValues['Department'] == 'Letters-Address Proof'
but here i got the below error
Cannot get property 'Department' on null object
Tarun Sapra
cfValues is already available in workflow post-function and not in script console. I meant try to write contains function in the script console like
def value = "Letters Address proof testing"
value.contains("Letters")
//and now in your post-function you can replace the value with the cfValues['Department'], it's only meant to test out the string contains method.
Yogesh Mude[Jira]
February 6, 2017
if i use .contains() method then it gives me error like
can not find matching method
Tarun Sapra
Did you cast it to (String) ? First cast it to string and then call the method contains()
Yogesh Mude[Jira]
February 6, 2017
sorry i cant get it can you please write the code here
Yogesh Mude[Jira]
February 6, 2017
@Tarun Sapra can u help me out here to get it done.
JamieA
February 12, 2017
Yogesh Mude[Jira]
February 13, 2017
Hi @Jamie Echlin (Adaptavist),
i am looking for the functionality that whenever the issue will be created by user then the emil should send to that user/reporter with one invoice.docs file.
The file will be same for all user/reporter so for this sending attachment file is i have to store this file some where else or else just need to specify that file name?
JamieA
February 21, 2017
Where does the attachment come from? If it's from the current issue you can use a custom closure to define that: https://scriptrunner.adaptavist.com/latest/jira/builtin-scripts.html#_attachments_in_emails
Help us plant more trees
