In Jira service management 5.4 I have to disable the JSM notifications and use a scriptrunner email instead when an issue is resolved.
But I still want the customers to receive the customer satisfaction survey.
How can I add it, in the scriptrunner email?
For your requirement, you could use the Send-Custom Email post-function, i.e. whenever the issue transitions to Done, for example, the custom email is triggered.
And for the template, I have run a basic test using the free survey template available at https://github.com/herbigt/npsmail.
Below is a screenshot of my Send Custom Email configuration:-
Below is a screenshot of the survey mail produced:-
I hope this helps to answer your question. :-)
Thank you and Kind regards,
Ram
