How to set Baseline Dates to match Target Dates
Isabella Musial
January 2, 2024 edited
I am trying to create a Manual Automation Rule that would set the Baseline Dates to match Target Dates.
  1. IF Baseline Dates are empty
  2. AND Target Dates are populated
  3. THEN set Baseline Dates to match Target Dates
  4. SO:
    1. Baseline start date = Target start
    2. Baseline end date = Target end
My Rule:
However, I get an Error editing issues
DTO-11807 (Error parsing date string: (customfield_16818))
I also tried just using the following in place of the "More Options".
The Audit Log shows it was successful, but the field did not update.
I think my error is in the JSON, but could be wrong. I have tried the following in "More Options":
"customfield_16818": "{{issue.Target start.startDate.jiraDate}}"
"Baseline start date": "{{issue.Target start.startDate.jiraDate}}"
"Baseline start date": "{{issue.customfield_10103.startDate.jiraDate}}"
Thank you in advance for your help!
Isabella Musial
GOT IT!!!
I was definitely overthinking it! This worked.
Ryan M
Is there a chance that the fields are of different types, for example date vs date time, therefore inputing the wrong formatting for the field value?
Can you try adding a log option before the "edit issue" and try to use that to print what the smart value for {{issue.Target Start.startDate.jiraDate}} is to the audit log to make sure that value exists and is correct?
 https://support.atlassian.com/cloud-automation/docs/debug-an-automation-rule/
Isabella Musial
Thanks! I just tried that - didn't really return anything in the Audit Log. I may be doing something wrong, though.
Clark Everson
I don't have those fields in my instance or even comparable ones to test but the JSON may possible be off. Myspacing below maybe off but even the target fields have custom field values so possibly try that
"fields": { "customfield_XXXXX": "{{issue.customfield_YYYYY.jiraDate}}"
Isabella Musial
I tried that one, too.... that didn't do it. My Baseline start date still did not update sadly. Audit Log says no actions performed.
"fields": { "customfield_16818": "{{issue.customfield_10103.jiraDate}}"
Isabella Musial
This may not be related to this response, but I also tried using the dropdown and selecting Baseline start date (customfield_16818) and entering the Target start (customfield_10103).
My Audit Log shows success - but the Baseline start date was not updated.
Isabella Musial
Also tried the following in the Baseline start date field (above) to no avail!
{{Target.startDate.jiraDate}}
{{Target start.startDate.jiraDate}}
Audit Log keeps telling me that my issue was edited successfully...
