How to set Fix Vesion/s field by version id from JIRA REST API
Hisamitsu Koga
I want to set "Fix Version/s" field by version id from JIRA REST API. How can I call JIRA REST API
to implement this request exactly? Please let me know the exact JIRA REST API command?
If possible, please let me know how I need to call JIRA REST API to set "Fix Version/s" field by version name
as well.
Bharadwaj Jannu
August 9, 2016
Which version of JIRA are you using? If you have CURL installed in your machine, you can use CURL to call REST URLs.
You need to prepare small json data to set/update Fix Version/s in an issue. Check JF's comment in https://answers.atlassian.com/questions/47904/what-is-the-rest-api-call-for-adding-a-fix-version-to-a-jira-item
Hisamitsu Koga
Using JIRA Server 6.4.13 here now.
atlassian, state of product 2026 webinar, product team report, webinar, product management, ai productivity, agile practices, team alignment, product report, atlassian learning, product strategy, discovery to delivery, survey insights
Webinar: State of Product 2026
We asked real teams how they’re coping with an industry in flux. Join this webinar to hear the research –plus tips for leveling up your team’s work.
Register now
